You can customize ArcGIS Community Analyst by setting preferences for the application, workflows, and reports and infographics. Save your settings and refresh the application to apply them. Administrators can set preferences for the entire organization. The most recently saved change for any preference, whether set by you or the administrator, is reflected as your current setting.
Set general app preferences
You can set preferences for the general appearance and functionality of the app.
- On the top ribbon, click Preferences .
The Preferences window appears.
- Expand the General section and click Settings. Do any of the following:
- Use the Default country drop-down menu to choose the preferred country for use in the app. If there is more than one data source for the chosen country, use the Data source drop-down menu to specify the source.
- Use the Default units drop-down menu to choose miles or kilometers.
- Use the Default basemap drop-down menu to choose a basemap.
- Use the Location pin symbol drop-down menu to choose or upload the preferred symbol for point locations on the map.
- In the Points of interest data source section, use the Select data source drop-down menu to choose a source for use in points of interest search, void analysis, and nearby locations when building reports.
The Points of interest data source preference is only available for countries with more than one points of interest data source option.
- In the Default map location section, provide an address in the Zoom to location field or pan and zoom the map in the Location preview window to set a preferred map extent for when the app opens.
- Optionally, restore the default settings by clicking Restore defaults. To save your changes, click Save or, optionally, click Save and close to close the Preferences window. To view your changes, refresh the app.
Set guided tour preferences
You can set preferences for guided tours of the app.
- Expand the General section and click Guided tours. Do any of the following:
- Use the Always show tips check box to turn expanded tips on or off when using guided tours.
- Click Reset all tours to reset your progress in guided tours and start again from the beginning. This option resets all guided tours. You will also lose all points and badges earned so far. This action cannot be undone.
Set project preferences
You can specify preferences for working with projects, including the projects page, opening new projects, clearing the map when switching projects, and the Save created sites window. See Create and use projects for project preference instructions.
Set data aggregation preferences
You can set preferences for the levels of polygon generalization and data aggregation.
- Expand the General section and click Data aggregation. Do any of the following:
- Under Analysis polygons tolerance, use the slider to specify the level of detail used for input polygons generalized for analysis, reports, and sharing. The slider presents a range between better performance and better precision. See Polygon generalization for more information.
- Under Detailed data aggregation, use the check box to specify whether detailed data aggregation is used. See Data apportionment for more information.
Set map detail preferences
You can set preferences for the borders, labels, and map legend that appear on your map. Border and label options vary depending on the country or region you've selected.
- Expand the Maps section, expand the Map details section, and click Boundaries. Do the following:
- Click a geographic area.
- In the Labels section, use the color swatch and text formatting drop-down menus to set the preferred text appearance.
- In the Borders section, use the color swatch, Transparency slider, and Thickness drop-down menu to set the preferred border appearance.
- In the Map details section, click Map legend. Use the Open the map legend by default check box to turn the map legend on or off.
Set workflow preferences
You can set preferences for specific functionalities and workflows in ArcGIS Community Analyst. For settings available in the Preferences window, refer to the tables below.
Add data
Learn more about workflow-specific preferences using the following links:
Specify preferences for the Web maps and layers window by adding another organization that appears in the Choose source organization drop-down menu. | |
Specify preferences for the colors and symbology of imported points and polygons. | |
Turn the workflow intro page on or off and decide whether to show warning messages when custom data is accessed from multiple sources. |
Create maps
Set color, transparency, and border preferences for the map and choose preferences for data breaks. | |
Turn the workflow intro page on or off and set preferences for overlay transparency and color. | |
Choose a symbol for search results and turn industry descriptions on or off. |
Define areas
Specify preferences for the appearance of sites on the map, as well as values and settings for rings, drive times, and walk times. | |
Specify preferences for the appearance of sites on the map. | |
Run analysis
Turn the workflow intro page on or off, set color defaults, and adjust the point layer influence to be positive or negative. | |
Turn the workflow intro page on or off, set calculation preferences for the reference area, and style the analysis and reference areas. | |
Turn the workflow intro page on or off, specify preferences for the threshold variable, threshold values, threshold type, map styling for rings and drive times, and other settings. |
Share results
Set reports and infographics preferences
You can set preferences for building and running reports and infographics in ArcGIS Community Analyst. For settings available in the Preferences window, refer to the tables below.
Overall settings
Learn more about overall report and infographic preferences using the following links:
Edit classic Esri report subtitle and specify preferences for intro pages and dialog boxes when running and building reports. | |
Add and preview logo images to appear on classic Esri reports. | |
Nearby locations | For reports, set symbol preference and maximum number of locations. For infographics, set symbol preference, maximum number of locations in tables, and other nearby location table preferences. |
Infographics
Learn more about infographic preferences using the following links:
Select the infographic to display in the site menu, set default display preferences, and set other infographic preferences. | |
Set preferences for exporting infographics to PDF and image, HTML, Excel, and for batches of infographics. | |
Select units of measurement used when building infographics. | |
Set color and label font preferences for display of comparison geographies in infographics. | |
Set preferences for the comparison geography, tables, word clouds, and threshold values when running interesting facts infographic panels. |
Classic reports
Learn more about classic report preferences using the following link:
Select the report to display in the site menu and set preferences for batch exporting, all-in-one reports, and data aggregation. |
Comparison reports
Learn more about comparison report preferences using the following link:
Specify preferences for the colors used to depict comparisons and the geography levels compared. |
Favorites
Learn more about favorite reports preferences using the following link:
Select classic Esri reports as favorites, specify the preferred report format, and edit favorites list. |
